Take a new Hurco or Takumi machine for a spin, 60 days, in your shop, on your parts.
No purchase commitment. Your local distributor installs it, trains your team, and you run production. If it performs the way you need, keep it. If not, send it back. Simple.
Request Your Test DriveProgram runs November 3, 2025 through [PROGRAM END DATE]. Spots are limited.
You don't run parts in a demo room. The Test Drive Program puts a machine into service for 60 calendar days in your environment, on your work, not a perfect sample part.
The trial clock starts at machine commissioning. Put it to work, not on display.
Your local distributor installs the machine and trains your team at no charge, so you're up and cutting fast.
Trial desktop software plus a 60-day full software suite comes with the machine for the evaluation period.
If the performance meets your goals, complete the purchase and the machine stays right where it is. If not, return it when the trial ends. No pressure either way.
U.S. and Canadian shops that are new to Hurco or Takumi, or that haven't purchased from us in 10 or more years. A Hurco North America Regional Manager reviews each request before approval.
Select in-stock machining centers and turning centers. Bridge mills larger than the H10, boring mills, and double-column machines are not eligible.
Your distributor commissions the machine and trains your team. Then you run production and see for yourself what the machine does for throughput, finish quality, and setup time.
Buy it or send it back. We have a guess as to which choice you'll make.
Submit a short request and your local Hurco or Takumi representative will contact you to confirm eligibility and next steps.
Test Drive offer is valid from November 3, 2025 until [PROGRAM END DATE]. Test Drive period is 60 calendar days from the time of machine commissioning. Customer must be new to Hurco/Takumi or have not purchased from Hurco/Takumi in 10 or more years. Valid only on select in-stock models. Ineligible machines: bridge mills larger than H10, boring mills, and double column. No special pricing or promotions may be combined with Test Drive sales. Includes trial desktop software and 60-day full software suite. Final approval for Test Drive qualification is at the sole discretion of Hurco North America. Offer valid in the U.S. and Canada only. Program may be modified, extended, or discontinued at any time without notice. Machine information may change without notice. Additional terms and conditions apply.
