3D Surfacing in Conversational Programming
February 3, 2022
WinMax 3D Import screen showing a solid model with dome, cone and pyramid surfaces
Conversational programming has always been a great choice for getting jobs up and running quickly and for very efficient programming of 2D and 2.5D contours and features. However, machining actual 3D surfaces required the use of a CAD/CAM software package – that is, until now!
3D Import and Solid Models
Hurco released the capability for the very popular 3D IMPORT option of the WinMax control. 3D IMPORT allows the user to program conversational blocks from a variety of drawing files, including .STP solid models. By simply clicking features on the model, the user can create conversational blocks to create the program and machine the part.
This was a real game changer for shops whose customers only provide them with solid models of their parts rather than paper prints. As design software became more and more prevalent, this “solid model only” scenario grew and caused many shops who otherwise loved conversational programming to find other programming alternatives, even for the simplest of work. Without paper prints at the machine, it makes conversational “shop floor” programming very difficult.
The release of the 3D IMPORT option addressed most of the issue for these shops, but there was still a need for offline programming for surfacing or true 3D contour work. With the Mill Surface feature of 3D IMPORT, these shops now have a conversational option for programming almost all their work.
WinMax Mill Surface conversational block with roughing settings for a ball end mill
Mill Surface Is Included With 3D Import
The Mill Surface feature of 3D IMPORT is an included capability within the overall option, and nothing separate or additional is necessary to purchase or install. Any existing users of older versions of 3D IMPORT can simply update their control software to utilize this standard feature.
Tool Tilt for 5-Axis Machines
The feature even allows you to program a tilt angle of the tool for 5-axis machines. By simply clicking on the handles attached to the coordinate shown below, you can manually drag it to the desired tilt angle, or enter a value in the provided A, B, or C fields at the bottom of the screen.
WinMax 3D Import screen with coordinate handles used to set the tool tilt angle for 5-axis machining
