Topic/Category: WinMax
What is Transform Plane?
Transform Plane
The Hurco WinMax control is programmed using Universal Rotary for multi-sided programming. Simply program the tool as it would rotate around the part, and don’t think about how the part is moving.
  • Designed to operate on any 4 or 5-axis Hurco machine
  • Control determines the necessary rotary movements based on the axes available
  • All rotations are incremental from original WPC
  • Programs can be shared between different machine configurations​​​
Click here to download the WinMax Transform Plane Quick Reference Guide​
