PROBLEM: Program and Machine Speed compatability issue
SOLUTION: (1)Reduce Program Feed rate (2) do not use axis over ride pot while program is running (3) power down the control (4) If problem persists, send a copy of the program with error message to [email protected] or contact Hurco Technical Support for other solutions.
